Write to relation table in other than FileGDB
sigtill
Forum|alt.badge.img+24
Similar to FileGDB (https://knowledge.safe.com/questions/1652/writing-relationships-in-esri-file-geodatabase.html)
Is it possible to easily write to a relation-table on MS SQL? And other databases? I see the db_relationship does not exist in those formats
Best answer by takashi
Hi @sigtill, I sometimes add a foreign key constraint to tables with a SQL statement written in the 'SQL Statement to Execute After Translation' parameter for the database writer. e.g.
alter table table1
add constraint fk_table1_table2 foreign key (id)
references table2 (id);
  • September 1, 2016
alter table table1
sigtill
  • September 1, 2016
alter table table1
Well, I need to insert to table1 first, then the join table1-2, then the features in the table2. So using your approach might not work? Would be great if you could do it the same way as with FileGDB.
  • September 1, 2016
Relationships in traditional SQL databases (non-SDE) work a bit differently than in e.g. a FileGDB, there is no such thing as a relationship-table. The relationships between two tables are defined with foreign key constraints only, the relationships aren't materialized in separate entities.
If we use Takashi's example, it means that you'll first have to write the data in "table2" before you can write the data to "table1", since it references "table2". In FME this often means having to use two writers, one for "table1" and one for "table2", then making sure that "table2" is written first by having it at the top of the Navigator.
If you think this is a hassle, consider voting for the idea I posted earlier today :-)
Let me know if I've misunderstood your question.
  • September 1, 2016
If the table1 and table2 will be created by the same workspace, you can create the tables and define their relationships (all the constraints) through the 'SQL Statement to Execute Before Translation'. e.g.
FME_SQL_DELIMITER ;
create table table1 (
  id integer,
  something varchar(100)
  constraint pk_table1 primary key (id)
create table table2 (
  id integer,
  constraint pk_table2 primary key (id),
  constraint fk_table2_table1 foreign key(id) references table1 (id)
In this case, be aware that the schema definitions in the writer feature types should exactly match the CREATE statement.
  • September 1, 2016
How about this? There may be some variations depending on the timing for creating the tables.
mark2atsafe
Forum|alt.badge.img+44
  • September 1, 2016
You can - with 2016 - set the order in which connections fire. Maybe that would help? You could have a single writer and two tables written in order. You might need to have the two connections emerge from the same transformer, which would complicate things.
  • September 1, 2016
That's great to hear, Mark. I think this new functionality has escaped me a bit, do you have any pointers that explains it in more detail?
sigtill
  • September 1, 2016
Thanks for the answers! I had an option similar to Takashis, however I struggled with the Featurewriter finishing before starting to use the writer. Using the Creator Featuremerger solves that issue, thanks @takashi
