Write "" in a csv
vijays
A simple question ->
I want to write "" value in a field in a csv file using csv writer.
When this csv file is opened in notepad, the value should look at "" and not as """""".
E.g. Note the third column, that is how it should be visible.
ID,Name,Comment
12,Vijay,""
13,Sambhe,""
Its odd but that is the requirement. I can add a workspacerunner, read csv as texfile and replace """""" as "" and write to a textfile but I want this to be done in a single workspace.
Thanks,
Vijay
Forum|alt.badge.img+49
On the CSV writer parameters you can set the option "Qualify Field Values" to No, that will disable that behaviour. However, if you have a field which contains a comma (or whatever you set as the field separator) you'll have a problem.
vijays
  • February 4, 2019
Thanks for looking into this.
I had tried that but then the default value of "" comes as blank value in the csv file.
I want the value in the csv file (if you view by opening it in notepad) to be written as
100,200,300,"","","",500
See the quotes.
Thanks,
Vijay
vijays wrote:
See the quotes.
Thanks,
Vijay
Okay, I think I figured it out.
First of all you should use a NullAttributeMapper to map null (or empty/missing) values to "". But in the writer parameters you also need to set the Field Qualifier Character to something other than "
I'm also not sure if other software will read the file properly. For example if you want to read the same file in FME you'll need to set the Field Qualifier Character on the reader too. Same with Excel.
