Tiff 2 ECW without black background
koenvdw
Hi
I have a workbench that converts Tiff tiles into one jpeg2000 with a transparent background.
This is the bench:
When I replace the jpeg2000 writer with an ECW writer I get a black background.
When I load a jpeg2000 in Qgis, the background is transparent.
When I load the ecw in Qgis I have to select in the settings under transparency band 3 as transparency band and then it's like the jpeg2000, but with an extra step.
Sadly our customer works with CAD and there I cant remove the black background with a setting....
Am I doing something wrong?
  • April 1, 2020
It looks like NODATA isn't supported in ECW, see here http://docs.safe.com/fme/2020.0/html/FME_Desktop_Documentation/FME_ReadersWriters/ecw/quick_facts_ecw.htm
I suspect that you have use an alpha-band for the transparency. Have a look at the sample posted by @helmoet here: https://knowledge.safe.com/questions/42118/making-black-no-data-cells-transparent-in-ecw-rast.html
koenvdw
  • April 1, 2020
thx for your comment. Can you check the link you provided, because it's a link to this article...
  • April 1, 2020
Sorry about that. Fixed.
