The WFS reader always chooses the default srs
The WFS reader automatically chooses the default srs of a WFS layer. Is there any way to make it read the features in a different srs which is supplied by the WFS supplier (and so also listed as option in the WFS capabilities). Changing the coordinate system of the reader doesn't work. It will still request the features in the WFS default srs and then interpret it (wrongly) as the coordinate system set at reader level.
chrisatsafe
  • July 10, 2020
Unfortunately it looks like this isn't an option yet but another user has requested for a CRS parameter. Perhaps you could upvote the idea and provide your use case on that idea to help our product ownership team get a better understanding of how this is impacting your project!
https://knowledge.safe.com/content/idea/40894/add-crs-parameter-for-wfs-reader.html
becchr
Forum|alt.badge.img+25
  • July 10, 2020
Hi @gkoster, not sure if this solution is working in all cases but helped me before: adding the epsg-code to your WFS-address might help you too?
so for example if your WFS address is
http://mydomain.com/wfs?
make it
http://mydomain.com/wfs?srsName=epsg:xxxxxx
with xxxxx the srs you want, supported by the WFService ofcourse
Hope this helps?
