The esri shape file reader truncates attribute names to 10 character
  • Apr 15, 2018 1:11 PM UTC
  • 70 views
Why does the shape file reader truncate the names attributes to 10 characters on loading / inserting the reader? I have fme version (FME(R) 2018.0.0.1 (20180328 - Build 18295 - WIN64)) installed.
  • Apr 15, 2018 10:37 PM UTC
Hi @vandijkjoostjan, in any Esri Shapefile dataset, the length of every attribute name should be equal to or less than 10 bytes. It's a restriction according to the specifications of the format dBASE (DBF) which is adopted as the format of attribute table for the Esri Shapefile.
fmelizard
Forum|alt.badge.img+22
  • Apr 16, 2018 1:52 AM UTC
When you look at it in ArcGIS, do you see longer field names? I"m wondering if the metadata in the attached XML file provides longer name aliases?
Thank you for the information
