Text encoding/decoding
  • September 14, 2015
  • 63 views
Hi all,
If I have GML file (utf-8 encoding) with (e.g.) LATIN SMALL LETTER C WITH ACUTE which I want to insert into SQL Server table with SQL_Latin1_General_CP1_CI_AS collation, and want to be able to export that (imported) value from table to gml file, what should I do?
I tried text encoders/decoders, but without success.
Best answer by david_r
Hi
Thanks for the example and welcome to the wonderful world of character encodings ;-) The issue here is that the file is saved as UTF-8 (https://en.wikipedia.org/wiki/Unicode), but the contents are to be written to a table configured for ISO-Latin (https://en.wikipedia.org/wiki/ISO/IEC_8859) (which is a much smaller character set), and some of your special characters (such as ? and ?) aren't supported by the subset ISO-Latin1, which according to the error message, is what the target table is configured for.
You could try to convert the attributes to ISO-Latin2 (where these characters are supported) and hope that the database can handle them in some way, but it is a bit of a stretch:
If this doesn't work, consider removing the accents entirely (see https://knowledge.safe.com/AnswersQuestionDetail?id=906a0000000ckT7AAI) or use a StringPairReplacer for a more targeted approach, e.g. replacing ? with ch, etc
David
Hi
If you can give us a small, but complete GML block here, it might be easier to help you along.
David
  • September 15, 2015
Hi David,
GML features are too big for posting here, but here is a piece of two features with parent elements (all elements of interest is at the level of these two; all features are in
KAT_CadastreFeatureCollectionMembers element)
 <?xml version="1.0" encoding="utf-8" ?> <fgu:KAT_CadastreFeatureCollection>   <fgu:KAT_CadastreFeatureCollectionMembers>     <fgu:KAT_Katastarska_Opcina gml:id="LOCAL_ID_1">       <fgu:oid>1100100146866</fgu:oid>       <fgu:sifra>71051</fgu:sifra>       <fgu:naziv>Banovi?i</fgu:naziv>     </fgu:KAT_Katastarska_Opcina>     <fgu:KAT_Toponim gml:id="LOCAL_ID_120970">       <fgu:oid>1100100144884</fgu:oid>       <fgu:tip>O0902006</fgu:tip>       <fgu:naziv>Brezi?ki potok</fgu:naziv>     </fgu:KAT_Toponim>   </fgu:KAT_CadastreFeatureCollectionMembers> </fgu:KAT_CadastreFeatureCollection>
 Tag of interest is <fgu:naziv> These two contain two different characters, but all need to go into table with SQL_Latin1_General_CP1_CI_AS collation in that way so that I can read and write it back into GML file. How to implement this into FME (import and export  from GML in two different workflows)?
Thanks!
Hi
David
Well done! Thanks for explanation and solution, a lot.
