Temporary/WOrking files are not deleted at the end of the translation
  • Jan 31, 2019 10:22 PM UTC
  • 126 views
arthy
Forum|alt.badge.img+8
Hello,
Is there a way to force fme to delete all the temporary/working files at the end of each translation?
I'm working with huge las files and it is taking a lot of memory so that I have to manually erase such files before doing the next translation.
Thanks
Forum|alt.badge.img+63
It should, under normal circumstances, delete temporary files. However, in case of an FME crash this sometimes doesn't happen and the files become "orphaned". You can manually clear them through Tools -> Purge Temporary Files in FME Workbench (or by manually going to your FME temp directory and clearing it out)
arthy
  • Feb 1, 2019 11:09 AM UTC
@redgeographics,
My concern here is because there was no crash. The translation went well but those temporary files remain.
Furthermore, by clicling purge temporary files does not work. I have to manually delete in the folder %TEMp%
@redgeographics,
Okay, that is a concern indeed. I would recommend that you send this in to Safe's support to see if they can help.
fmelizard
Forum|alt.badge.img+22
  • Feb 2, 2019 4:52 AM UTC
Please do let support know. We'd need to see your workspace if at all possible, and also your log file if you can share that. Definitely it is a bug if these are being left behind.
