It seems that the FME translator for Smallworld applies the "unset value" to any field where the value is unset. Is it possible to export a null value instead. We would like to preserve the values as is and not have to try to come up with some convoluted process to deal with it. Only thought I have would be to pick a default value for each field that we know doesn't exist in any of the existing data. We would then have to look for those values after exporting the data from smallworld so we could then again put them back to null. That could be a lot of work for all of the different classes we need to export.
