Smallworld Dimensioning to ESRI 10.2.1 Dimensioning Feature class?
  • Feb 27, 2018 3:52 PM UTC
  • 96 views
Does FME support migrating Smallworld Dimensions to the ESRI Dimensioning Feature Class?
We probably need a someone in the community with more Smallworld experience to chime in regarding Smallworld dimensions. I know that in the past we have configured FME to extract dimensions from Smallworld to AutoCAD. The Smallworld 5.1 documentation mentions that dimension geometry cannot be exported, but I suspect that some magik configuration would turn that around. In older versions of Smallworld, I think how the dimensions had been configured would dictate if they could be accessed by FME.
Regarding Geodatabase: FME can write to dimension geometries, see the FME user documentation, and the section on Dimensions
