Shapefile to KMZ problem:
  • Nov 7, 2013 6:00 PM UTC
  • 6 replies
  • 85 views
jhawks
Forum|alt.badge.img+7
My first attempt at shape to KMZ is attached. I'm doing clearly several things wrong. Suggestions welcome.
http://fmeserver.ncd.noaa.gov/ge_error.png
I'm trying to produce:
http://fmeserver.ncd.noaa.gov/ge_charts.png
Which was created using Arc2earth which I no longer have acess to.
fmelizard
Forum|alt.badge.img+22
  • Nov 7, 2013 6:49 PM UTC
Are you using the KMLStyler? it looks like the opacity is not properly set.
Can you provide more information about what you are doing?
Itay
jhawks
  • Nov 7, 2013 7:24 PM UTC
I have a KML Styler but I havent hooked it to anything yet.
http://fmeserver.ncd.noaa.gov/workbench.png
fmelizard
  • Nov 7, 2013 7:46 PM UTC
As I remember the fill color opacity is set to semi transparent, you should have a look at the transformers parameters...
jhawks
  • Nov 7, 2013 10:24 PM UTC
Got it! Thanks!
http://fmeserver.ncd.noaa.gov/ge_yay.png
Next up how to do different colors for different scale bands of nautical chart footprints and why the charts that cross the 180 degree lin wrap around the world.
fmelizard
  • Nov 8, 2013 7:23 AM UTC
You can specify a different color attribute (fme_color) per group and use it in the styler, the writer will automatically interpret the fme_color to the kml color.
jhawks
  • Nov 14, 2013 8:45 PM UTC
So if I want to set different scale bands of maps to different colors I need to use the Parameter Condition Definition?
