Setting fme_db_operation value from an attribute
tim_wood
Forum|alt.badge.img+8
I have an FGDB feature class which includes a "DBOperation" attribute with values of INSERT, UPDATE, or DELETE. I want to assign these to fme_db_operation but when I do this in an AttributeCreator, it gets changed to...
<at>Value<openparen>DBOperation<closeparen>
I've changed the AtrributeCreator to Conditional Value which seems to be happier.
Has anyone else had this experience?
Best answer by david_r
I can confirm using both FME 2016.1.3 and 2017 RC, looks like a bug. Consider reporting it to Safe.
If I use an AttributeRenamer rather than the AttributeCreator it works fine, though.
  • January 31, 2017
erik_jan
Forum|alt.badge.img+18
  • January 31, 2017
I agree with @david_r. You should report this to support@safe.com
In the meantime: have you tried using the AttributeValueMapper instead?
tim_wood
  • January 31, 2017
Thanks. Yes I thought of that. I wanted to see if it was worth pursuing the idea of storing the db operation as an attribute in an FGDB for later use when updating ArcSDE.
tim_wood
  • January 31, 2017
Thanks, will do. AttributeRenamer is a good idea.
I've noticed when you create the fme_db_operation attribute, the value box changes to a drop down list of the allowed values. So there's obviously something special happening when setting that attribute.
