SDE (Sql Server) Truncate Issues - FME fails to truncate table
I have a client that is experiencing some odd behavior when it comes to truncating feature classes and tables in a SQL Server SDE environment. The writer is set to 'Yes' for Truncate table however when fme writes out the features heading to the writer it does not truncate the data first but merely inserts data records.
If i add a new reader, move the feature types over, configure it exactly the same and rerun the writer functions as expected (Truncate and Load data).
Why do i have to add a new reader that is configured exactly the same to get FME to truncate properly. Do FME writers go stale?
FME 2015.1
SDE (10.4.1)
Any help will be apprecaited.
  • June 26, 2018
Have you verified that the database user has sufficient grants for performing the truncate?
laddysmurf19
I am currently having this same issue and would love some help.
evieatsafe
  • March 17, 2025
Hi ​@laddysmurf19 thanks for your reply. Could you post a new thread with some additional details as well as link this thread for reference? This will get more eyes on your issue.
Some additional details to include that would be helpful:
  • what version of FME are you using?
  • what user permissions does your user have on your database?
  • are you getting any errors?
  • have you tried adding another writer, or updating your current writer to see if this improves the issue?
