Save .shp multipolygon to .wkt file
  • Nov 9, 2020 10:37 AM UTC
  • 139 views
Hello,
I am trying to save multipolygon .shp file to .wkt file. See attachment.
Is it possible to save the output of my workbench directly to the file with extension. wkt?
I noticed that .wkt Reader exist, but I cannot find Writer.
I know that I could save it to .txt, but it doesn't solve my problem because in the next step of the process I need to seed this file to external tool which reads only file with .wkt extension. I would like to avoid manual step of changing .txt file extension into .wkt as I would need to do it multiple times.
ogc_wkt
  • Nov 9, 2020 10:40 AM UTC
How about getting the WKT using the GeometryExtractor into the attribute text_line_data, then using the regular text file writer? It should be possible to set the output file extension there.
