Reading Pipe Networks from Civil 3D(2017 & older)
  • Jun 13, 2018 2:28 PM UTC
  • 114 views
Hi!
I am at the moment struggling with reading Civil3D Files(created in Civil 3D 2017/older). I end up with a lot of strange looking Chambers/Structures & most of the Pipes end up as lines.
Please see Pictures & attached Example File .
The Designer in this case i using a Plugin called "Naviate", which is mostly used in Sweden(I think). These Pipe Networks are also modeled with a huge radius(Which is a bit uncommon I believe). Therefore I thought this could be the source of the problem, and tried creating test networks in a "plain" Civil 3D, to check if it´s due to the Designer/plugins/etc. However I end up with the same result.
-Any known bugs?
-Possible to get a test Workspace + test File?
-Any guidance on the Topic would be vary helpful.
I attended an inspiring presentation by Dale, showing a neat workflow to handle the Civil 3D Files & the object. Note sure if this was in the 2019.1 version, but as I understood, this should also be possible in the 2018.0(?).
From "FME World Tour in Stockholm 2018". One beautiful Civil 3D Model.
What I end up with. A lot of strange looking objects.
Regards
/Daniel
daveatsafe
Forum|alt.badge.img+24
  • Jun 13, 2018 5:19 PM UTC
Hi @danielloov,
The Pipes you provided seem to be standard drainage pipes, which FME should be able to read. I have created a problem report for our development team, and I will notify you as this problem is fixed.
  • Oct 10, 2018 7:47 AM UTC
@DaveAtSafe any news on the Topic?
daveatsafe
  • Oct 10, 2018 4:17 PM UTC
Hi @danielloov,
I'm sorry, we are still working on finding the cause of this problem. I will notify you as soon as it is fixed in beta.
