Reading multi-patch geometry from File GeoDatabase
  • September 19, 2017
  • 250 views
I am trying to read a multipatch geometry from ESRI File Geodatabase and getting the following error:
FME API version of module 'FILEGDB' matches current internal version (3.8 20170315) FileGDB Reader: Feature class '*****' has shape type 'esriGeometryMultiPatch' which is unknown to FME. Skipping feature class
(I am using OSX version of FME Desktop 2017.1, build 17539). I was wondering if it's supported on Windows with FGDB (ArcObject based format). Is MultiPatch Geometry reading supported by FME using Shapefiles?
I appreciate any advice on this (puzzling for me) question.
Kind regards,
Alexander
Best answer by geosander
The File Geodatabase API can't read multipatch features, unfortunately. This is not a shortcoming of FME, but caused by Esri's API that is rather limited.
There are a couple of other options:
1) You'd have to use the ArcObjects reader instead. But then you need to switch to Windows and buy an Esri license...
2) You need to find a way to export your File Geodatabase to a multipatch shapefile (no wonder that format is still so popular...) and read that with FME to process it further.
geosander
Forum|alt.badge.img+7
whkarto
Forum|alt.badge.img+14
Keep in mind, that Shape Multipatch doesn't support texture!
geosander
True, yes, thanks for the addition.
