Reading a tsv file
  • September 5, 2024
  • 43 views
p15rajan
Hello there,
How can I read a tsv file in FME? Do we need  to use csv format only:?
Siva
Best answer by mark2atsafe
Yes, you can use the CSV format and just change the delimiter in the parameters dialog.
There’s also a CAT (Column Aligned Text) format too, if the contents are aligned like that.
mark2atsafe
Forum|alt.badge.img+44
  • September 5, 2024
p15rajan
  • September 5, 2024
Thanks very much for your prompt reply
