Read/Write Access to DWG Summary Info (DWG Properties)?
  • Jan 23, 2021 3:21 PM UTC
  • 0 replies
  • 82 views
I managed to add SummaryInfo Comments (also known as DWG properties) to DWG files (created by FME Desktop) using ObjectDBX in a Windows Powershell  post process and wonder if it is possible to do it directly in FME Desktop:
$srcDir = "C:\DWG\infiles\"
$tgtDir = "C:\DWG\outfiles\"
$errorFile = 'C:\DWG\error.log'
$comments = 'C:\DWG\comments.csv'
$AutoCad = New-Object -ComObject Autocad.Application
$AcadVer = $AutoCad.ActiveDocument.GetVariable("ACADVER")
$AcadVer = $AcadVer.Split(".")[0]
$DbxId = "ObjectDBX.AXDbDocument."+$AcadVer
$Dbx = $AutoCAD.GetInterfaceObject($DbxId)
foreach($line in Get-Content $comments -Encoding UTF8)
  $data = $line.Split(";")
  Write-Host $data[0]
  try{
    $Dbx.Open($srcDir+$data[0]+".dwg")
    $Dbx.SummaryInfo.Comments = $data[1]
    $Dbx.SaveAs($tgtDir+$data[0]+".dwg")
  catch{
    $error_msg = $srcDir+$data[0]+".dwg"
    Out-File -FilePath $errorFile -Append -InputObject $error_msg
Write-Host "Error: ",$data[0]
comments.csv:
4233-15_1;Last Change - VA40:21.10.2020
4234-31_3;Last Change - VA40:21.10.2020
4234-31_4;Last Change - VA40:21.10.2020
4234-32_1;Last Change - VA40:21.10.2020
As a workaround/hack in FME Workspace, I added a temporary DXF header with the included comments to my DWG Writer , but unfortunately this only works with "AutoCAD DWG Writer" and not with "RealDWG Writer" anymore (FME Desktop 2020.2 Windows 10/64bit).
2 years ago I had no problems adding DXF headers to DWG files using RealDWG, but the current FME version can't add these headers with the REAL driver. I really need the RealDWG Writer to prevent these annoying TrustedDWG messages 😉
