read dat from $(FME_SHAREDRESOURCE_DATA)
  • Jun 28, 2017 9:50 AM UTC
  • 99 views
pschout
Forum|alt.badge.img+7
Is it possible to read data from $(FME_SHAREDRESOURCE_DATA) with the feature reader? In a workspace i write excel datasets to $(FME_SHAREDRESOURCE_DATA), I want to read these because they contains attributes which i need to dicede to send a mail (or not) with another job.
(The full path to the data is :
$(FME_SHAREDRESOURCE_DATA)/Informatie_Management/Vaarwegmeldingen/Meldingen_borden.xls)
I use FME server 2015
  • Jun 28, 2017 9:52 AM UTC
Yes, that should definitely be possible. You can both read and write to subfolders under FME_SHAREDRESOURCE_DATA.
