Paged WFS Responses - OS Features
  • Feb 27, 2023 7:26 AM UTC
  • 153 views
adrian_farrell
Hi
I have a requirement to connect to the new Ordnance Survey (GB) WFS service in FME, their system responds with 100 records at one time, there doesn't appear to be an option in the reader to facilitate this paging implementation as in other products
Any help to be able to access this API would be greatly appreciated
Best answer by nielsgerrits
Just tested on "Zoomstack_Contours" and works for me. I used a FeatureReader, choose WFS version 2.0.0 and set Start Index to 0.
Attached the workspace, don't forget to replace the dummy key with your own and you're good to go.
(Output Ports are now set to Single Output Port, but you can change this when you have updated the Dataset url with a valid key.)
nielsgerrits
Forum|alt.badge.img+67
  • Feb 27, 2023 7:54 AM UTC
adrian_farrell
Thanks, it worked perfectly.
I hadn't chosen WFS v2.0.0
od10
Forum|alt.badge.img+4
  • Nov 22, 2024 10:32 AM UTC
Hi ​@nielsgerrits
Is there a way to use the spatial filter on the bounding box reader? I can’t get this to work for me?
Thanks,
nielsgerrits
Generally speaking it is preferred to create a new topic for a new question.
When using a FeatureReader to read the WFS you are able to use the geometry of the initiating feature as spatial filter. Sample attached.
But if you want to use a XML Filter Expression, please visit https://olivers-expression-lab.gitbook.io/filter-expressions-in-fme which explains in detail how this works. Thanks again ​@oliver !
This works as XML filter:
<Filter>
    <BBOX>
        <PropertyName>Name>NAME</PropertyName>
        <Box%20srsName='EPSG:28992'>
            <coordinates>131088,523596 131588,524096</coordinates>
        </Box>
    </BBOX>
</Filter>
