ORA-12592 and ORA-03135
  • Feb 16, 2017 7:33 AM UTC
  • 37 views
raimond
Forum|alt.badge.img+7
The translation is running and writing records to Oracle. But suddenly i get an Oracle error ORA-12592 or ORA-03135 and the translation stops.
The database is online.
What can cause this problem.
  • Feb 16, 2017 8:21 AM UTC
Make sure your Oracle client drivers are up to date. Also maybe try restarting the Oracle listener, if possible. Finally, check your physical network connections. It's very unlikely an FME problem.
