Need to read a SVG file (Scalable Vector Graphics )
I need to read a SVG file but in FME, SVG  writer is present but no reader. Is there a way to read the SVG file. Any help would be appreciated.
Thanks
davideagle
Forum|alt.badge.img+21
  • April 24, 2013
Sorry, it's only possible to Write SVG with FME http://www.safe.com/fme/format-search/. If its practical, you might have to consider using an online converter to translate the SVG file to another raster format like PNG that FME can read.
  • April 24, 2013
To add to Dave's answer: there seems to be some dedicated programs out there that can convert SVG to other vector based formats, such as DXF (here is one I found through Google, but have not experience with, so caveat emptor).
Might be an alternative to research further if you can justify the cost / effort in your project.
David
gio
Forum|alt.badge.img+15
  • March 17, 2014
I always use Inkscape to convert to dxf.
If needed you can restrucutre your svg by using layers.
Of course u need to georeference after export (using some GIS aplication, Q-GiS is open source).
Actually Q-gis can read and write svg, unlike fme (wich is a shame..;))
Never fails.
I got here because i was llokin if the was a reader for svg yet..btw)
Gio
