MSACCESS_JDBC Reader fails to obtain table schema's in FME Desktop 2019
ireen
Forum|alt.badge.img+5
The MS Access (JDBC) Reader gives an error reading table schema's in FME 2019. The workspace still works fine in FME 2018.1, but generates the following log in version 2019.0:
MS Access (JDBC) Reader: Connected to 'UCanAccess driver for Microsoft Access databases using HSQLDB' version 'V2007 [VERSION_12]' using driver 'Ucanaccess' version '4.0.4' built against JDBC version '4.0'
MS Access (JDBC) Reader: Error reading schema for table 'qry02_Energiesnoeiers'.  Error: <null>
java.lang.NullPointerException
    at COM.safe.fme.jdbc.msaccess.MsAccessBackendHelper.createColumnMetadata(MsAccessBackendHelper.java:343)
    at COM.safe.fme.jdbc.JdbcBackendHelper.getTableSchema(JdbcBackendHelper.java:129)
    at COM.safe.fme.jdbc.JdbcReader.readSchema(JdbcReader.java:948)
    at COM.safe.fme.jdbc.JdbcReader.readSchemaHelper(JdbcReader.java:872)
    at COM.safe.fme.jdbc.JdbcReader.readSchema(JdbcReader.java:830)
Failed to obtain any schemas from reader 'MSACCESS_JDBC' from 1 datasets. This may be due to invalid datasets or format accessibility issues due to licensing, dependencies, or module loading. See logfile for more information.
 Anyone an idea how to solve this?
ravenkopelman
This one will be hard to solve without sample data and (possibly) a workspace. If you file an issue at https://www.safe.com/support/ I will try to investigate ASAP.
ireen
  • August 22, 2019
I just made a case (C147649) with attached database and workspace.
ravenkopelman
Thank you! It appears we broke support for older databases when adding support for new datatypes in modern databases. A fix will be made to FME 2019.1+.
A possible workaround would be to resave the database in a newer version of Access, but it's not a sure fix.
ireen
  • August 23, 2019
OK, thank you for the information.
