Merging XML Childs to a new Child with multiple ocurrences
  • Apr 22, 2016 3:15 PM UTC
  • 12 replies
  • 82 views
hordor
Hi, I have an XML-File which I read with flattening. Part of the XML structure is something like:
<element>
   <points>
       <startPoint>
          <value1></value1>
          <value2></value2>
       </startPoint>
       <middlePoint>
          <value1></value1>
          <value2></value2>
       </middlePoint>
       <endPoint>
          <value1></value1>
          <value2></value2>
       </endPoint>
   </points>
</element>
StartPoint and Endpoint must occur once, middlepoint can occur many times. I have to transform this in a structure like:
<element>
   <newpoints>
       <pointNumber>
       <value1></value1>
       <value2></value2>
   </newpoints>
</element>
Obviously newpoints must occur at least twice. Any Suggestion how to combine those points with different attribute-names into the newpoints?
Thanks!
mark2atsafe
Forum|alt.badge.img+59
What you should get when you read that data are attributes like:
points.startPoint.value1
points.startPoint.value2
points.middlePoint{}.value1
points.middlePoint{}.value2
points.endpoint.value1
points.endpoint.value2
The {} part in the middlePoint attribute denotes a list, because there can be more than one value.
You can run through that list in the XMLTemplater using something like:
<xml>
for $x in fme:get-list-attribute("points.middlePoint{}.value1")
return <list_entry>{$x}</list_entry>
</xml>
I can't quite get it to work and I'm afraid I have a meeting to run to now. But I'm hoping this will get you started. The whole template would have the start and end points around the middle ones.
 And what I'm really not clear about is nesting those loops - because you need one for value1 and value2. I'm not too hot at XQuery. But like I said, this should be a good starting point.
mark2atsafe
  • Apr 22, 2016 10:56 PM UTC
<xml>
</xml>
OK. It works to an extent. I used this template:
<xml>
<newpoints>
<value1>{fme:get-attribute("points.startPoint.value1")}</value1>
<value2>{fme:get-attribute("points.startPoint.value2")}</value2>
    return <value1>{$x}</value1>
<value1>{fme:get-attribute("points.endPoint.value1")}</value1>
<value2>{fme:get-attribute("points.endPoint.value2")}</value2>
</newpoints>
</xml
What I can't seem to get is the middle value1/value2 pairings. If I run two for loops consecutively then I get all the value1's then all the value2's.
If I nest the loops I get each value1 paired with each value2, which is also incorrect.
I somehow need to interleave the two queries. Maybe @takashi knows of a way to do this? I will perhaps post it to StackOverflow too, as someone there may know.
patrick_koning
Forum|alt.badge.img+7
I think a subtemplate is the way to go here.
Explode the list before the xmltemplater en put it in the subtemplate port.
I include an example to illustrate.subelementsxmltemplaterexample.fmw
Hopes this get you on your way
  • Apr 24, 2016 1:40 PM UTC
hmm..., my posts in this thread won't appear anyway.
Retry, again. This is the latest example: xmltemplater-example-4.fmw
hordor
  • Apr 25, 2016 8:43 AM UTC
I tested these solutions and it works fine for me. ThankYou!
  • Apr 25, 2016 4:22 PM UTC
<xml>
<newpoints>
</newpoints>
</xml
Hi @Mark2AtSafe, maybe this template expression works as your expected. The combination of temporary XML fragment creation and nested "for" iteration does the trick. Assume that the "_num" attribute stores the number of all points = 2 + number of "points.middlePoint{}" list elements.
<element>
<newpoints>
<pointNumber>1</pointNumber>
for $x at $i in fme:get-list-attribute("points.middlePoint{}.value1")
let $a := fn:concat("points.middlePoint{", {$i}-1, "}.value2")
let $t :=<tmp>
    <pointNumber>{fn:sum(({$i}, 1))}</pointNumber>
    <value2>{fme:get-attribute($a)}</value2>
    </tmp>
return {for $v in $t/* return $v}
<pointNumber>{fme:get-attribute("_num")}</pointNumber>
</newpoints>
</element>
I don't know why my previous posts in this thread don't appear...
Retry.The attachment is a workspace example using XQuery: xmltemplater-example-2.fmw
[Update] xmltemplater-example-3.fmw
[Addition] @Mark2AtSafe, this seems to be a smarter way to manipulate a structured list in an XQuery expression.
<element><newpoints><pointNumber>1</pointNumber><value1>{fme:get-attribute("points.startPoint.value1")}</value1><value2>{fme:get-attribute("points.startPoint.value2")}</value2>{let $v1 := {for $v in fme:get-list-attribute("points.middlePoint{}.value1") return $v}let $v2 := {for $v in fme:get-list-attribute("points.middlePoint{}.value2") return $v}for $i in (1 to fn:count($v1))return (<pointNumber>{fn:sum(($i, 1))}</pointNumber>,    <value1>{$v1[$i]}</value1>,    <value2>{$v2[$i]}</value2>)}<pointNumber>{fme:get-attribute("_num")}</pointNumber><value1>{fme:get-attribute("points.endPoint.value1")}</value1><value2>{fme:get-attribute("points.endPoint.value2")}</value2></newpoints></element>
Simpler XQuery expressions flashed. Nested iteration is not essential in this case :)
XMLTemplater_B:
<element>
<newpoints>
for $x at $i in {fme:get-xml-attribute("xml_fragment")}/element/points/*
return (<pointNumber>{$i}</pointNumber>, {$x/value1}, {$x/value2})
</newpoints>
</element>
XMLTemplater_C:
<element>
<newpoints>
return (<pointNumber>{sum(($i, 1))}</pointNumber>,
    <value1>{$x}</value1>,
    <value2>{fme:get-attribute($a)}</value2>)
</newpoints>
</element>
<xml>
<newpoints>
</newpoints>
</xml
OK. It seems that the 'fme:get-list-attribute' function just returns a sequence of values, so this expression is also possible.
<element>
<newpoints>
let $v1 := fme:get-list-attribute("points.middlePoint{}.value1")
let $v2 := fme:get-list-attribute("points.middlePoint{}.value2")
return (<pointNumber>{$i + 1}</pointNumber>,
</newpoints>
</element>
<xml>
</xml>
This expression also works. # hopefully this post will appear...
<element>
<newpoints>
for $i in (0 to fn:count(fme:get-list-attribute("points.middlePoint{}.value1")) - 1)
return (<pointNumber>{$i + 2}</pointNumber>,
<value1>{fme:get-attribute(fn:concat("points.middlePoint{", $i, "}.value1"))}</value1>,
<value2>{fme:get-attribute(fn:concat("points.middlePoint{", $i, "}.value2"))}</value2>)
<pointNumber>{
fn:count(fme:get-list-attribute("points.middlePoint{}.value1")) + 2
}</pointNumber>
</newpoints>
</element><br>
  • Apr 25, 2016 10:23 PM UTC
the XMLXQueryUpdater may be a better choice in this case. My final example: xqueryupdater-example.fmw
  • Apr 26, 2016 12:02 AM UTC
ok. my previous posts all are displayed now. I've removed excess posts.
