LiDAR .las files
  • Jul 24, 2013 6:52 AM UTC
  • 47 views
Hi
I have just received LiDAR data in .las format. I am using MapInfo but cannot directly open them in this program. I also have access to Engage 3D (but not Pro)
Can someone please help me with advice as to how I go about converting them in FME workbench into a usable format for MapInfo.
Essentially I would like to get contours, point data (x, y, z) as well as being able to create DEMs. Must warn you I don't use FME often - so please dumb down any advice.
Thanks in advance.
Keiryn McCartney
GIS Technician - GTCC
Best answer by conterrastefan
Hi Keiryn,
for general examples with point clound data, you can check this link:
http://fmepedia.safe.com/topic/Point-Cloud
There is one example, how you can create a DEM. So in the first step it would be good to filter out your relevant data (-> points for DEM) and then write it to Mapinfo. I jsut checked the FME readers and writers gallery and in the MapInfo Spatial Ware (Database) z-values are supported. So that could be an approach...
Best regards,
Stefan
Hi Keiryn,
Best regards,
Stefan
