License Error when Reading or Writing to Esri Geodatabase
  • Mar 18, 2015 7:32 PM UTC
  • 59 views
ahmad_saleh
The following link (http://fmepedia.safe.com/articles/Error_Unexpected_Behavior/FME-cannot-read-or-write-to-Esri-Geodatabase-license-error-messages) is describing this issue, but there is no details on how to really fix it, I am using ArcGIS 10.3 with a floating license and FME 2015 with floating license too, and I am still unable to Read or Write to Esri Geodatabase. On ArcGIS 10.2.2 and FME 2015 I can read and write Geodatabases whith the same types of licenses without any problems, Should I downgrad may ArcGIS products or what !!
Any help is appreciated
Best Regards,
Ahmad
  • Apr 1, 2015 1:27 PM UTC
Hi Ahmad,
Sorry to hear you are having this problem - these two products should definitely be compatible.
Is your FME definitely a 32 bit FME?  Because ArcGIS 10.3 is a 32 bit application you must use a 32 bit FME.  Also you aren't running ArcGIS Pro are you (which is 64 bit)?
Otherwise please have a look at this page on FME compatability with ArcGIS:
http://fmepedia.safe.com/articles/Samples_and_Demos/Notes-on-FME-and-ESRI-Versions-and-Compatibility
Thanks
Ken
ahmad_saleh
Hi Ken,
Many thanks, Yes I am using FME 2015 32 bit, and ArcGIS desktop 10.3, I couldn’t figure out why I am still having this issue !!
Thanks,
Ahmad
