LAS to Landxml (autodesk)
  • Jun 19, 2017 4:27 PM UTC
  • 416 views
Hi !
I would like to know if it's possible to transfert LAS files to Landxml ?
Just like XML files are exported from a surface in Autocad.
The purpose of this transformer is to load LandXML surface into Autocad Infrasworks as a Terrain so i can drape Buildings/Roads/City Furniture/Streams on it.
Let me know if you think it's possible.
Best regards
mark2atsafe
Forum|alt.badge.img+59
The Readers and Writers manual tells me that Landxml allows surface features, so the answer is probably yes. Try the PointCloudSurfaceBuilder transformer to convert the point cloud into a mesh surface and try writing that.
Depending on how the point cloud was captured I guess you might also need to filter its content using the PointCloudFilter before trying to create a surface from it.
