Is it possible to change the text size when writing ArcGIS Pro geodatabase annotation?
  • June 21, 2021
  • 68 views
I am writing to an ArcGIS Pro annotation feature class in a file geodatabase defined where the text symbol is not required to be selected from the symbol table. My intent is to change the size of the text and have the symbol stored inline, but have been unsuccessful in my attempts. The font size always ends up as 10. This doesn’t seem to be related to the definition of the annotation class symbol, as I have created annotation classes with different size symbols and the resulting size is always 10.
I am setting the following attributes in the workbench and exposing these on the writer:
  • geodb_text_size: 72
  • geodb_symbol_id: -1
  • geodb_anno_class_id: -1
  • geodb_allow_symbol_overrides: TRUE
  • geodb_font_point_size: 72
fme_pro_annotation_writer
In my testing I have been able to change these properties and see the results come through:
  • geodb_text_color
  • geodb_font_name
I have tried using the TextPropertySetter to change the text size but that doesn’t translate to the resulting annotation.
I did try running this with FME 2020.1 against a standard annotation geodatabase feature class and the text size was updated.
Update 7/23/21:
I was pointed to an FME article on setting geodatabase annotation size:
Article Detail (safe.com)
I followed these instructions. The geodatabase writer does not have a geodb_font_size like the article describes. It does have a geodb_font_point_size, which I set in lieu of geodb_font_size, but it did not change the resulting text size.
fme_pro_annotation_font_size
Using:
FME 2021.0.3.0 (20210528 - Build 21326 – WIN64)
ArcGIS Pro 2.4.2
  • August 3, 2021
Safe support came through on this. While the geodb_font_size attribute isn't exposed in the writer format attributes setting it will still work to change the font size.
