Indexing results in Translation Logs
mr_fme
Forum|alt.badge.img+8
I'm reading around 5 million rows from the 252 Excel files. I need to view the rows to delete many columns and edit values, but indexing the results is taking a long time
How can I improve this?
Thank´s
stalknecht
Forum|alt.badge.img+19
  • February 25, 2024
Sorting is time consuming maybe you can use a tester or testfilter to filter out the desired features. You can then use a sorter to sort the features.
nielsgerrits
Forum|alt.badge.img+54
Or create your workspace with a representive sample and do a production run when ready.
danilo_fme
Forum|alt.badge.img+42
  • February 25, 2024
@mr_fme André, você está usando o Data Interoperability?
