Improve on GeoJSON
  • Aug 24, 2017 8:45 AM UTC
  • 115 views
From this Q&A;: Geojson reader-encoding issue
The Source URL: http://stadtplan.bonn.de/geojson?Thema=14403&koordsys;=25832/geojson.json
I think there is a room to improve GeoJSON handling.
  • The GeoJSON reader should support various encodings.
  • The GeoJSON reader and the GeometryReplacer (Geometry Encoding: GeoJSON) should set an appropriate coordinate system to the geometry if the "geometry" member object contains a valid "crs" member, like this.
   "type" : "FeatureCollection",
   "features" : [
         "type" : "Feature",
         "geometry" : {
            "type" : "Point",
            "crs" : {
               "type" : "name",
               "properties" : {
                  "name" : "EPSG:25832"
            "coordinates" : [ 369127.5691, 5624581.982 ]
         "properties" : {
deanatsafe
  • Aug 25, 2017 1:43 AM UTC
Hi @takashi,
Thanks for pointing out these issues. We certainly would like to make it as easy as possible to work with JSON data, wherever it may come from. In regards to encodings, normally the standard for JSON is to use unicode - UTF8 or UTF16. The data stream here is system encoded to charset = ISO-8859-15. Still, the HTTP header does have this information and the reader could in theory use this to help interpret the data. One work around is to use an HTTPCaller to read this URL, with Response Body Encoding = 'Autodetect from HTTP header'. Then connect the output to a JSONFragmenter, JSONQuery = 'json', fragment as format = 'GEOJSON'. This will allow you to read this data stream into FME features. I would agree that ideally the reader should be able to make use of this header content type information as well, so I have filed an enhancement request to that effect. See: readnonutfjson-httpcaller20171.fmw
With regards to the coordinate system, it already is standard functionality that the GeoJSON reader to set an appropriate coordinate system if the geometry member contains a valid CRS. The issue here is that the CRS property is a child member of the geometry and not a property of the parent feature, so the GeoJSON reader didnt find it. We have already made a fix to handle both cases properly in the future. You will see this fix soon in an upcoming FME 2018 beta.
Note that the latest version of the GeoJSON specification will only support LL84 CRS. In FME we will continue to support past specifications and default to using the latest specification for writing. Note the writer parameter - Reproject to WGS84 = Yes by default.
See: https://tools.ietf.org/html/rfc7946#section-4
  • Aug 25, 2017 2:56 AM UTC
Hi @takashi,
Hi @DeanAtSafe, thanks for your clarification.
Your workaround - HTTPCaller + JSONFragmenter is the same as the second solution I have suggested in the comment to the original question, but I didn't know the "Fragment as Format" parameter in the JSONFragmenter has been restored in FME 2017.1.
I remember that the parameter (called "Explode as Format" before) had been once deprecated in FME 2016. I contacted your Support team at that time.
C114423 - JSONFragmenter: 'Explode as Format' parameter was deprecated?
The answer was: "I spoke with our developer and he mentioned that the Explode As Format option was removed as they were wanting to have the JSONFragmenter be more of a true JSON transformer (i.e. have less to do with Formats and more to do with actually JSON manipulation)."
I thought the reason was reasonable, but it's also good that the parameter became available again. Anyway, however, the help doc should be updated to describe about the parameters correctly.
