How to write IfcTesselatedItem?
  • May 7, 2020 9:20 AM UTC
  • 97 views
Hello,
I have troubles with the creation of IfcTesselatedItem.
When I create an IfcBuildingStorey object in a FME Workbench (v. 2020)
automatically IfcProject, IfcSite, IfcBuilding and IfcBuildingStorey are created in the ifc file:
Otherwise, if I create a IfcTesselatedItem
only IfcProject is created:
How it's possible to create IfcTesselatedItem objects with FME?
Thanks for all suggestions and help
Best answer by daveatsafe
Hi @franco,
The Tesselation is a geometry type in IFC, not a feature type, so you can't write it directly. The solution is to write a feature with a Mesh geometry to IFC instead. I am attaching a simple workspace to illustrate.
writeifctesselation.fmw
daveatsafe
Forum|alt.badge.img+24
  • May 11, 2020 6:54 PM UTC
Hi @franco,
  • May 14, 2020 10:45 AM UTC
Hi @franco,
Thanks @daveatsafe! It's exactly what I needed. Perfect! Thanks again!
