How to use acess/excel writer more elegantly?
  • Nov 6, 2014 8:28 AM UTC
  • 5 replies
  • 51 views
Dear FME community,
if I add an access writer, FME asks me for a file name, of course :). This name is then displayed in the Navigator window, e.g. "filename [MDB_ADO]". The feature type corresponds to the table name, like in an excel writer. If want to add another access database with different attributes, I always have to add another writer (not feature type!). In difference to for example the mapinfo writer where the feature type corresponds to the file name, in access/excel it only refers to the database/table name.
What I want to do is use the existing (one) writer and just add another feature type. This would have the advantage that if I change the directory, I would only have to change one path in one writer, not in every access writer.
Does anyone know who to handle this?
Kind regards
Thomas
fmelizard
Forum|alt.badge.img+22
  • Nov 6, 2014 9:27 AM UTC
gio
Forum|alt.badge.img+15
  • Nov 6, 2014 10:37 AM UTC
Hi Thomas.
If u create a writer for acces, excell, autocad etc. U create a "dataset".
So all u have to do is create a single writer.
U will have a dataset with one table/autocadlayer/excelltab.
If u copy/paste this writer in the workspace and rename it..you will add another table/autocadlayer/excelltab to the existing dataset.
the "featuretypes" are the names of the instances of the writer in the workspace wich are therefore tabels,tabs, layers in a dataset or file.
The datasetname is "fme_basename"
When u for instance create a fanout attirubte and set writer to fanout, an excell would have as many tabs.
If u open the writer in the navigator pane, u see first the basename. At the end you see featuretypes. These are the names of the tables,tabs,layers in your Acces/Excell/autocad files.
thats all there is to it.
gio
  • Nov 6, 2014 10:38 AM UTC
..i should spellcheck more...i know ;)
  • Nov 6, 2014 11:48 AM UTC
Gio is right. Dataset and Feature Type are fundamental concepts of FME, but their physical forms are different according to formats.
For some formats, a folder is a dataset; a file (set) is equivalent to a feature type (e.g. Esri Shape, MapInfo Tab). For other formats, a file is a dataset; a layer, worksheet, or table etc. is equivalent to a feature type (e.g. AutoCAD DXF, Microsoft Excel, Access). and so on.
See also here.
FME Workbench Help > Datset Types (http://docs.safe.com/fme/html/FME_Workbench/Default.htm#dataset_types.htm)
# I've got used to your tricky spelling ;)
Takashi
  • Nov 6, 2014 12:22 PM UTC
Hey guys, I found a solution!
After you have added the access writer, you can set  "Fanout Dataset" under "Advanced". With the option "Attribute to Fanout on" set to fme_basename, it creates a new access database file for each incoming feature type (i.e. mapinfo dataset) that enters. It doesn't just add another table/spreadsheet. Thats's exactly what I was looking for.
Kind regards
Thomas
