How to tranform json results into shapefile?
  • Mar 6, 2020 11:54 AM UTC
  • 6 replies
  • 162 views
In the following snippet (which has been reduced in length from the above file) are the results from a web api. I need to create a point for every coordinate pair and add the relevant attribute data to the point table. I am having problems due to the ID of each feature e.g. "535412" which envelopes the other attributes.
How can I manipulate the json file to be able to write a shapefile with the attributes as fields?
        "Results": [
            "535412": {
                "Standortbescheinigungsnummer": "021296",
                "PostalischeAdresse": "Gstraße 8, 35560 Musterort",
                "Standortbescheinigungsdokumente": {
                    "AktuellsteStandortbescheinigungsdokumente": {
                        "STOB": "15ba5116-be92-4c61-8a72-22d605b70f",
                        "TD": "e3452231-0f4f-4d10-8b38-40386acd1a"
                "KOORD_NORD_DEZ": 53.117221,
                "KOORD_OST_DEZ": 9.791388
            "545123": {
                "Standortbescheinigungsnummer": "021626",
                "PostalischeAdresse": "VStraße 32, 23994 Musterort",
                        "STOB": "70da0d00-2e18-4427-acd7-f8c2e9f11e"
                "KOORD_NORD_DEZ": 53.134722,
                "KOORD_OST_DEZ": 9.769166
danilo_fme
Forum|alt.badge.img+58
  • Mar 6, 2020 1:05 PM UTC
Hi @robertdbuckley
DId you try to use the transformer JSONGragmenter and expose the attributes:
Thanks in Advance,
Danilo
jdh
Forum|alt.badge.img+41
  • Mar 6, 2020 2:20 PM UTC
Tricksy.
I expect you'll have to use x-query fn:node-name to extract the id as a value rather than an attribute name.
esietinga
Forum|alt.badge.img+7
  • Mar 6, 2020 2:46 PM UTC
I replaced the square brackets "[" and "]" with curly braces ( "{" and "}" respectively with two string replacers. Then use an JSONFragmenter (JSON Query: json[*][*], recursive flatten objects? No) and expose the required attributes. Rename attributes as required
examplejson.fmw
examplejson.fmw
Unfortunately I can't get this to work adaquately.
mark2atsafe
Forum|alt.badge.img+59
Try json["Ergebnisliste"][*] in the JSONFragmenter. Set Flatten Query Results into Attributes = Yes.
Then you should get one FME feature per ID number, and the NORD and OST coordinates are exposed.
mark2atsafe
