How to get data type of fields/attributes in a shp file
  • October 22, 2020
  • 279 views
Looking to drop a shp file into workspace and extract the data type of each field. e.g. Address.shp may have fields StreetName (text) and StreetNumber (int). I would like to be able to extract the type for each field:
StreetName - fme_char(254)
StreetNumber - fme_int32
I understand that FME maps the Data Types from different files based on the reader being used to an equivalent FME Data Type https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Workbench/!FeatureTypeProperties/attribute_types.htm
Best answer by ebygomm
Another option is to use FeatureReader to read the shapefile and choose to read Schema features only. The schema is returned as a list, so you would need a list exploder to break each list element into multiple features.
oscard
Forum|alt.badge.img+21
  • October 22, 2020
There is a Reader called Schema. I think it would give you the info you are looking for.
Forum|alt.badge.img+32
  • October 22, 2020
  • October 22, 2020
I think this way works the best for my use, as I can just drop in one shape file and specify a user parameter in the FeatureReader transformer to extract the schema from it.
