How to Extract Coordinates from Oracle Spatial Object Table
Hello, I've searched all available online sources but none appear to have this issue.
Very simple task: I've added an Oracle Spatial Reader, connected to desired table and now want to extract x/y but I get this error when running.
"Error - Cannot have NULL value for 'z coordinate'"
I've looked at the table in Oracle developer and indeed the Z values are Null.
I'm aware that this table has multiple Spatial columns so I've checked: Handle Multiple Spatial Columns: Yes
I've tried a SELECT statement to run before translation:
SELECT c.GEOM.SDO_POINT.X AS X, c.GEOM.SDO_POINT.Y AS Y,
FROM A.ENTITIES c
WHERE ACCESS_CODE = 'O'
I've tried to expose the attributes:
oracle_sdo_point.x
oracle_sdo_point.y
oracle_sdo_point.z
Is there a way to force this to 2D rather than looking at the Z values?
Any ideas appreciated.
pratap
Forum|alt.badge.img+11
  • March 29, 2017
When you are query the data for X and Y coordinates then you will get only 2 coordinates. I'm not clear on what is the need to force to 2D... Any how if your data has z coordinate and want to convert to 2D use 2DForcer...
Hope this helps...
erik_jan
Forum|alt.badge.img+17
  • March 29, 2017
Oracle Spatial can store points in two ways.
The first (and best) is to use the SDO_POINT constructor. In that case the SQL you used should work.
But the point can also be created using the SDO_ORDINATES array.
In that case the SQL will look like:
Select c.GEOM.SDO_GEOMETRY.SDO_ORDINATES(1) as X etc.
Hope this helps.
gio
Forum|alt.badge.img+15
  • March 29, 2017
actually, there is a vertex extractor, I believe in the utilities package.
Hope this helps.
Thanks for your help Erik but it didn't work.
Here's the format of the GEOM column if that helps.
MDSYS.SDO_GEOMETRY(3001,8311,MDSYS.SDO_POINT_TYPE(149.49654,-27.84651,NULL),NULL,NULL)
