How to Convert the Last Character to Lowercase if it's an Uppercase Letter in FME?
  • Sep 5, 2024 2:08 PM UTC
  • 164 views
1sean
Forum|alt.badge.img+4
Hello everyone,
I'm looking for a way to check if the ending character of a string attribute is an uppercase letter, and if so, convert it to lowercase. For example:
  • Foo1K → Foo1k
  • BAR4 → BAR4
  • BAZ → BAz
What's the best way to accomplish this in FME? Are there any specific transformers or approaches that I should use to achieve this result?
Best answer by dustin
You can do this in an AttributeCreator with the following string. This example assumes your attribute name is ‘att’.
@Substring(@Value(att),0,@Evaluate(@StringLength(@Value(att))-1))@LowerCase(@Substring(@Value(att),-1,1))
dustin
Forum|alt.badge.img+36
  • Sep 5, 2024 2:24 PM UTC
1sean
  • Sep 5, 2024 2:33 PM UTC
Worked perfectly. Thanks @dustin!
