How do I convert a Raster file to COG (Cloud optimised Geotiff) with 4 bands (R,G,B,Alpha)?
davidlee
Forum|alt.badge.img+7
I want to convert JPEG file (4 band) to COG with below parameter:
I have problem with “Interleaving Type”:
When i chooses “BIP”, i received a message log:
COG writer: JPEG compression supports at most 3 bands with BIP interleaving. Please change the interleaving to BSQ, choose another compression method, or reduce the number of bands
When i chooses “BSQ”, i received a message log:
COG writer: The file layout 'Cloud Optimized Tiles' may only be used with BIP interleaving. Please change the interleaving to BIP or select a different file layout
I need to convert JPEG file to COG with compression method “JPEG” and keep alpha band.
Can i do that? Am I mistaken about something?
jkr_wrk
Forum|alt.badge.img+29
  • April 23, 2024
I am using FME 2021 and COG was not yet an option in that version.
So I downloaded GDAL COG library and do these conversions with that library, within FME.
jkr_wrk
  • April 23, 2024
import fme
import fmeobjects
import subprocess
import os
import mimetypes
class FeatureProcessor(object):
    def __init__(self):
        print("Initialise Python GDAL Conversion Library")
        # Path to folder containing GDAL
        gdal_folder = FME_MacroValues['GdalDir']
        os.environ["GDAL_DATA"] = os.path.join(gdal_folder, 'data')
        self.gdal_translate = os.path.join(gdal_folder, "bin", "gdal_translate.exe")
        options_cog_with_alpha = ["-of","COG" ,
          "-co","BIGTIFF=YES",
          "-co","COMPRESS=JPEG",
          "-co","QUALITY=90",
          "-co","BLOCKSIZE=512" ,
          "-co","OVERVIEWS=IGNORE_EXISTING"]
    def input(self, feature):
        print("Start Feature Conversion with GDAL to COG")
        file_dir = feature.getAttribute("LocalWorkDir")
        input_filename = feature.getAttribute("LocalFileName")
        output_folder = 'Converted'
        output_filename = feature.getAttribute("NewLocalFileName") + ".tif"
        input_file = os.path.join(file_dir, input_filename)
        output_file = os.path.join(file_dir, output_folder, output_filename)
        # Check if output directory exits, else create it
        if not os.path.exists(os.path.join(file_dir, output_folder)):
            print("Creating directory:", os.path.join(file_dir, output_folder))
            os.makedirs(os.path.join(file_dir, output_folder))
        print("Converting file:", input_file)
        print("to location:", output_file)
        # Run GDAL Translate to convert to COG
        subprocess.run([self.gdal_translate] + self.options_cog_with_alpha + [input_file, output_file])
        # Set MIME type attribute for the output file
        feature.setAttribute("ContentType", "image/tiff")
        print("Conversion to COG completed.")
        self.pyoutput(feature)
    def close(self):
        pass
I had AI strip the code to the bare basics. But this is an example of using the External GDAL Lib.
At start I used the GDAL Python module, but that did not have the functions I wanted to use.
davidlee
  • April 24, 2024
jkr_wrk wrote:
import fme
import fmeobjects
import subprocess
import os
import mimetypes
    def __init__(self):
          "-co","QUALITY=90",
    def close(self):
        pass
Thanks for your response.
I have tried to use your code and I also tried to use my code with GDAL lib, but both of them don’t work as expected. It just has 3 bands without Alpha band.
Perhaps COG doesn’t have the function for converting alpha band with compression JPEG.
I want to use COG on my geoserver to remove the black border after georeferencing RASTER with the smallest size.
Do you have any suggestions for me?
jkr_wrk
  • April 24, 2024
Maybe try LERC compression?
davidlee
  • April 24, 2024
I tried all of compression and I found that JPEG is the best compression in my case.
All remaining methods produce results with large capacity
