How do I bypass class extensions when reading from ArcSDE?
  • February 10, 2014
  • 34 views
I'm trying to read Feature Class from our Enterprise Geodatabase and because we have custom class extensions registered on all our our data.
I am not able to set the Reader to bypass the class extensions.
I get this warning in the log
"Unable to read from the table/feature class 'YK_SPATIAL.Buildings'. If 'YK_SPATIAL.Buildings' contains a class extension, make sure it is registered on this computer"
Thanks
pratap
Forum|alt.badge.img+11
  • December 4, 2015
Have you received/identified any solution for this problem?
Pratap
nielsgerrits
Forum|alt.badge.img+54
@pratap did you find a solution? I have the same problem with a Personal Geodatabase and FME (2016.1.0.1). ArcMap (10.2.2) errors with: "Unable to create class extension COM component". Google got me this: http://support.esri.com/technical-article/000002980 but as I have no experience with developing in ESRI products I like to check for other solutions before divining in.
srayford
  • September 12, 2019
After I installed ArcSDE Command Line Tools, no more error.
felipeverdu
Forum|alt.badge.img+10
  • March 1, 2020
Hi @srayford
Good to hear that you solved this. Can you enlighten me how did you do that?
Best regards,
Felipe Verdú
