How can I convert polygons to DGN text
  • January 15, 2014
  • 5 replies
  • 21 views
Hi, I have a feature class of polygons that I would like to convert to a text layer in the DGN file with one of the attributes as the text shown. I have played about with GeometryCoercer and tried  changing the format attibutes (igds_type and igds_text_elements{}.igds_text_string) but cant get text to display in the place of polygons. Has anyone managed to do this?
Best answer by fmelizard
Try the LabelPointReplacer.
Itay
fmelizard
Forum|alt.badge.img+18
  • January 15, 2014
Itay
fmelizard
  • January 15, 2014
and then the TextAdder to transform it to text geometry.
  • January 15, 2014
Thanks, are there any guides to formatting the text. Is it by insering numbers to igds_text...  format atttributes
fmelizard
  • January 15, 2014
guides? not really you can however see the documentation of the StringFormatter for formating options.
Itay
fmelizard
  • January 15, 2014
Normally after labeling the features the fme_text_string attribute value will be transfered to the igds_text_string, automatically transfering the values.
Itay
