How can I change the Vertical Datum (Vertically Reproject) in a Raster DEM
  • February 28, 2018
  • 177 views
fmelizard
Forum|alt.badge.img+18
I have a raster in which I need to change the vertical datum. I tried using the CSMapReprojector but it didn't work. It looks like FME just always sees the Raster at 2D when I view it in the Data Inspector. Is this a bug?
Best answer by fmelizard
This is not a bug. FME will always interpret a raster as 2D. The height information is stored in the pixels of the raster image. To shift the vertical datum it's probably easiest to first convert it to a Point Cloud, then perform the vertical shift and then change it back into a Raster.
You can try it your self here: reprojectrasterheights.fmwt
(Data sourced from the City of Vancouver)
fmelizard
  • February 28, 2018
