Hosted Feature Service to word document
Hi there,
I have a hosted feature service which has to get updated with the records from a web app. On the basis of that, I would like to create a workbench where I can use the fields from hosted feature service and using a custom word template I can generate a report.
Any help regarding this is much appreciated.
Thanks,
Anu
friesewoudloper
Which version of FME are you using, 2018?
Did you already take a look at Esri ArcGIS Online (AGOL) Feature Service Reader, MSWordStyler transformer and MSWord Writer?
Thanks for the reply. Yes, I have had a look at AGOL FS Reader. I have managed to add the connection in FME. I couldn't get Portal added to FME is because of SSL certificate issue, which I am trying to resolve.
I have also found this transformer and writer you mentioned above and now looking into the detail help documents how I can use these. Is there any video available about all of these FME tools description?
As mentioned above I would like to use my custom report template to generate the report so any help regarding this would be appreciated.
Thanks,
Anu
