Google Earth Writer - kml id doc
  • Aug 10, 2018 3:10 PM UTC
  • 83 views
bubblebeb
I am writing some geom to a KML file and wanting to group the data by Phasing. I have used the feature type name to identify the grouping.
When it writes the KML the groups are shows as
kml_id_doc_1.1.11.4
kml_id_doc_1.1.11.5
kml_id_doc_1.1.11.6
Does anyone know what is going wrong and how I can fix it?
Thanks
danilo_fme
Forum|alt.badge.img+58
  • Aug 10, 2018 11:18 PM UTC
Hi @sebkingsley
Could you share us your Workspace and log file?
Thanks,
Danilo
jovitaatsafe
Forum|alt.badge.img+11
Hi @sebkingsley,
It would be helpful if you could provide a bit more information as danilo_fme has suggested, as well as what your desired output might look like.
In the meantime, perhaps a feature type fanout might be helpful for your translation. If your data is already grouped by Phasing, you can simply set the Feature Type Name as the attribute Phasing in your writer parameters. This way it will write out different KML folders for each grouped phasing.
