GeoPackage, Failed to add data - no such table main.GDB_Items
asablomberg
Forum|alt.badge.img+7
I am writing a geopackage file in FME but when I try to use it in ArcGIS Pro I get this error message. Any idea what could be wrong?
“Failed to add data ...main.GNG.anlaggningsomrade. Invalid parameter value passed to function[no such table: main.GDB_Items}”
FME Workbench 2022.2.2
ArcGIS Pro 3.2
Best answer by asablomberg
The problem was that since the layers had name ‘db-user.table-name’ then arcgispro thought it was an sde geodatabase. I had to rename the layers . → _ and then it worked.
nampreetatsafe
Forum|alt.badge.img+12
I was unable to reproduce the issue.  It might help share your workspace and sample dataset if possible. If you’d prefer, feel free to submit a support case, and we can look into this further.!-->
asablomberg
  • April 16, 2024
Thanks for your response. I registrered a support case with the workspace attached.
asablomberg
  • April 30, 2024
