geocode with own web service
apence231
Forum|alt.badge.img+7
I have my own ArcGIS Server GeoCode Service web service available and was seeing how do I use it with FME? I'm accessing a table thru ODBC which has addresses and turning it into a shapefile. Thanks!
Best answer by david_r
Hi
Look at the API specification for the geocodeAddresses (https://developers.arcgis.com/rest/geocode/api-reference/geocoding-geocode-addresses.htm)service.
You can either use an JSONTemplater or just hardcode your JSON into an attribute and pass it into a HTTPCaller that points to your server. You can use a JSONFlattener to convert the resulting JSON back into an FME feature for further processing.
David
  • August 10, 2015
Hi
David
bruceharold
Forum|alt.badge.img+17
  • January 6, 2016
You might like to leverage the code behind this sample:
http://www.arcgis.com/home/item.html?id=e57a7f9b15...
It gets fancy with threading but the basics of creating a recordset for geocodeAddresses is there.
