FME Server 2017.1 cant write to PostgreSQL DB
Tried to copy feature classes from a Microsoft SQL database to a postgresql database using SDE Connection files. The workbenche does fine on FME Desktop 2017 but on the fme Server 2017.1 i get following error:
"Could not open the Enterprise Geodatabase. The error number from ArcObjects is: '-2147155644'. The error message from ArcObjects is: {Cannot connect to database because the database client software failed to load. Be sure the database client software is installed and configured correctly.} "
stalknecht
Forum|alt.badge.img+19
The Arcgis client software should be installed on the server also. The engine must be 32 bits if u use 32 bits third party software.
  • August 4, 2017
it should be installed by arcmap Desktop ... or i am i wrong?
and all workbenches without postgre Connection working fine
stalknecht
Yep, is the engine 32 bits?
  • August 4, 2017
engine and server 64bit, arcmap Desktop (10.4.1) 32bit + backgroundgeoprocessing 64bit
stalknecht
Is your FME desktop instance where it's running correct also 64 bits?
  • August 4, 2017
the fme Desktop is 32bit
stalknecht
You've told me that in workbench 32 bits it is working. Either install 32 bits Engine or Esri 64 bit Background Geoprocessing Module on the server and Postgres should be in the same architecture you choose.
stalknecht
  • August 4, 2017
Esri 64 bit Background Geoprocessing Module is already installed and the postgre is 64 bit too
stalknecht
Could you check if you can write to postgres without using the SDE?
  • August 4, 2017
tested with direct conenction to the postgres database and it worked on the server
stalknecht
The Account running the engine must have administrator privileges. Can you confirm it has the administrator rights and is not local system?
stalknecht
Can you share the PATH variable from the server?
open a cmd-prompt and type path.
Link
  • August 7, 2017
Link
yes, the user running the fme Services is adminstrator
PATH=D:\\Python27\\ArcGISx6410.4;D:\\Program Files (x86)\\ArcGIS\\Desktop10.4;C:\\Wind
ows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowe
rShell\\v1.0\\;D:\\Program Files\\FMEServer\\Utilities\\jre\\bin\\client;D:\\Program File
s\\FMEServer\\Server\\fme;D:\\Program Files\\FMEServer\\
stalknecht
Can you change the path of the ArcGis libraries to a 64 bits path?
(the PATH you are listing is this the one you get when you are logged on as the user that's running the engine?)
  • August 7, 2017
there is no other arcgis path :S
yes, it is from the engine user
stalknecht
Here are some links for further investigation.
https://knowledge.safe.com/questions/1931/enterprise-geodatabase-readerwriter-failing-to-loa.html
https://knowledge.safe.com/questions/3950/problem-using-direct-connect-to-esri-geodatabase-f.html
http://support.esri.com/en/technical-article/000010576
If you still experience trouble create a support call. Your FME reseller can do this for you.
best regards,
Wilko Stalknecht
steveatsafe
Forum|alt.badge.img+12
I have seen some misleading messages from ArcMap before. Is it possible something else is interfering here? Is your FME Desktop and FME Server on the same system where this is working? Seems like it is an ArcGIS issue. Can you connect to the postgreSQL DB OK with the ArcGIS software (on the same system that FME Server is installed)?
  • August 9, 2017
The FME Desktop and Server are on different machines.
Yes, i can connect with ArcMap on the Server sytem to my postgrs db
