FME Ifc to Revit
  • May 28, 2020 3:24 PM UTC
  • 0 replies
  • 69 views
Hello folks,
I have another question for you , which I'm having trouble solving.
I have made an IFC 3d model which I try to import into Revit. Although my walls are redirected to the Walls family in Revit, they each make up an entire family with their own instance.
So I figured I would use the example of the LOD 200 Ifc file from the FME blog here in the BIM examples to see if this would give the same result.
Now when I import the sample data into Revit I get the same 'error' that I get with my own model. The only difference is that in the LOD 200 sample some of the walls are redirected to the basic walls family whilst others are getting redirected to their own family with their own instance.
So my question: How do I get my walls in the basic wall family of Revit. At which point in the converting/importing process is this 'error' taking place and how can I solve it. Because now I can't alter the family of the walls when I import them into Revit.
Thanks in advance!
Andreas
