Filter geometry by layer names in FeatureReader with dynamically defined AutoCAD file as the dataset
  • Sep 18, 2017 2:25 PM UTC
  • 122 views
bo
Forum|alt.badge.img+10
With FeatureReader, if an AutoCAD file is dynamically assigned as the Dataset via attribute, how can we filter geometries on certain layers by the layer names? Here is the image of the transformer's property definition showing the specific ports manually entered which was later ignored.
Best answer by ulfme
Hi!
You should be able to browse ("...") for Feature Types to Read and then select Feature Types from a sample dwg (or several) when the dataset is set by an attribute:
/Ulf
ulfme
Forum|alt.badge.img+14
  • Sep 18, 2017 3:01 PM UTC
Hi!
/Ulf
bo
  • Sep 18, 2017 4:22 PM UTC
Hi!
/Ulf
Excellent, @ulfme! I did not know what to do with the "Unresolved Parameters" and it turned out to be the ticket!
