Expose 'Group' element in Microstation DGN V8 file.
I am using FME 2017.1 and would like to expose the Microstation DGN V8 attribute called 'Group' circled below in the screen shot (Attribute value is 'D' in this case).
I have exposed all the 'Format Attributes' in the DGN Reader and looked through the Reader parameters but cannot find this attribute anywhere.
Does anyone know how to do this?
Thanks,
danilo_fme
Forum|alt.badge.img+42
  • June 1, 2018
Hi @aquamarine,
Did you expose all elements and it not show? Could you send the file DGN?
I have the version FME 2018.
Thanks,
Danilo
  • June 1, 2018
Hi @danilo_fme I have opened it in FME 2018 also and exposed all the attributes. But it is still not coming through...
danilo_fme
  • June 1, 2018
Could you share with me this file?
  • June 4, 2018
danilo_fme wrote:
Hi @aquamarine,
Thanks,
Danilo
Hi @danilo_fme
Do you have an email address I can send it to?
Thanks
danilo_fme
  • June 4, 2018
aquamarine wrote:
Hi @danilo_fme
Thanks
Yes. danilo@solutial.com.br
  • July 2, 2018
I have posted an idea about adding the 'Named Group' value as an attribute that can be imported using the Microstation DGN Reader.
https://knowledge.safe.com/idea/73541/add-functionality-in-the-microstation-dgnreader-to.html
