Error while reading WFS Datas
  • November 14, 2017
  • 28 views
I can get my Feature Types, but when I connect them to an Inspector, I can't read more than 150000 entities.
I get this message :
Is this an error because of my parameter ou because of the WFS Data ? I'm using FME Desktop 2017 (build 17652, 32-bits and 64-bits version). My project use only about 300 Mo RAM.
I keep the WFS Reader's default parameter, except :
Max Feature : 150000
WFS Version : 1.1.0
WFS Output Format : GML 3.1.1
Connection & Transfert Timeout Length : 1000 s
If I set "Max Features" to 100000, I can visualise my datas.
Thanks for any help or advice ^_^
Patrick
danilo_fme
Forum|alt.badge.img+45
  • November 14, 2017
Hi @patoche94,
I tried with sucess to read your WFS in FME Data Inspector:
Your log file is show the GML file has a error.
Thanks,
Danilo
trentatsafe
  • November 14, 2017
Hello @patoche94,
Does the error occur with reading a specific layer, or with any of the layers within the WFS?
I believe FME is merely returning the error it receives from the server. In this case, the out of memory error appears to be occurring on the server side and FME is merely relaying the error.
  • November 15, 2017
trentatsafe wrote:
Hello @patoche94,
You're right, it's quite strange : Yesterday, I have read more than 155000 entities. So today, I try to find which layer does not work.
Thanks for your help !
  • November 15, 2017
danilo_fme wrote:
Hi @patoche94,
Thanks,
Danilo
Thanks Danilo, you're right : the problem seems to occur when I build the GML file. There are probably some wrong entities
