Error to write Polygon in ElasticSearch
danilo_fme
Forum|alt.badge.img+42
I have a Workspace that Read two ( 2 ) files Polygons from Shapefile and generate with Success in ElasticSearch, but in Point geometry:
My question is: How can i respect the geometry from my Polygons and write polygons in ElasticSearch?
Attached the log file and Workspace template ( .fmwt ). -
Thanks,
Danilo
Best answer by jakemolnar
If you open up the writer feature type parameters, look for this setting:
Table > General > Type Mapping Creation Parameters > Geometry Fields
You should find a table of geometry fields and their types. Simply change the type of your geometry field from `geo_point` to `geo_shape`; this will cause the Elasticsearch writer to store your polygons as GeoJSON polygons rather than as the center point of the shape.
Certain Elasticsearch functionality can only be used with either `geo_point` or `geo_shape` geometry fields, so be sure to have a look at the Elasticsearch documentation on this subject (geo_point docs, geo_shape docs)
jakemolnar
  • October 25, 2017
jakemolnar
Oh, also, you'll need to overwrite your index. That's the only way to change the type of a field, and you are changing the geometry field type from `geo_point` to `geo_shape`.
To have a look at your type mapping, I believe you can run this in kibana console: `GET /polygon/city/_mapping`
danilo_fme
  • October 26, 2017
@jakemolnar, thanks your help. It was powerful with my case.Congrat!!!
