Editing XML File
Hello everyone,
I want to make changes to existing XML files based on Microsoft Word in FME Desktop 2015, for that I use the XMLReader (Elements to Match: *; Flattening enabled and using the workflow Option Single Merged FT) and the XMLWriter.
All I did by now is connecting the reader and the writer to get an exact copy of the XML file, but it creates an XML File including tags (<fme:*>) that I don't want to be in there.
For example:
 <fme:xml-tables xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:fme="http://www.safe.com/xml/xmltables" xsi:schemaLocation="http://www.safe.com/xml/xmltables FME_EDDH2_Testfile.xsd"> 	<fme:family-table> 		<fme:family> 			<Relationship xmlns="http://schemas.openxmlformats.org/package/2006/relationships" Id="rId3" Type="http://schemas.openxmlformats.org/officeDocument/2006/relationships/extended-properties" Target="docProps/app.xml"/> 			<fme:xml_id>id-Relationship-1.1.1.1.1</fme:xml_id> 			<fme:xml_matched_element>Relationship</fme:xml_matched_element> 			<fme:xml_parent_child_pos>0</fme:xml_parent_child_pos> 			<fme:xml_parent_id>id-Relationships-1.1.1.1</fme:xml_parent_id> 			<fme:Relationship.Type>http://schemas.openxmlformats.org/officeDocument/2006/relationships/extended-properties</fme:Relationship.Type> 			<fme:Relationship/> 			<fme:Relationship.Id>rId3</fme:Relationship.Id> 			<fme:Relationship.Target>docProps/app.xml</fme:Relationship.Target> 			<fme:Relationships.xmlns>http://schemas.openxmlformats.org/package/2006/relationships</fme:Relationships.xmlns> 		</fme:family> 	</fme:family-table> </fme:xml-tables>
 Is it possible to create such a copy with the XML Reader/Writer? Am I missing a setting?
I also noticed that the declaration
 <?mso-application progid="Word.Document"?>
 was missing in the created XML file and I can't find it in the User Attributes.
Any help is appreciated
Melanie
  • May 18, 2015
Hi Melanie,
You can control the target namespace and its prefix through these parameters of the XML writer.
Target Namespace URI
Target Namespace Prefix
To omit the namespace prefix, specify a URI to the "Target Namespace URI" explicitly and leave the "Target Namespace Prefix" blank. e.g.
Target Namespace URI: http://www.my_domain.com/my_schema
Target Namespace Prefix: <not set>
Regarding the missing "<?mso-application progid="Word.Document"?>".
It's not a standard XML element, maybe is a Microsoft specification.
I don't think that the XML reader can read it, because it's not a part of the XML document.
Takashi
  • May 18, 2015
the "<?mso-application progid="Word.Document"?>" part is an XML processing instruction (http://en.wikipedia.org/wiki/Processing_Instruction).
The easiest solution is probably to just concatenate that bit (as a constant) onto the XML string just before sending it to the writer.
David
  • May 19, 2015
Thanks for your help.
Using the XMLReader and XMLWriter causes some Problems in my case so i decided to use the Text File Reader and Writer.
I also tried the XMLUpdate Transformer, but somehow it doesn't change anything. For testing I used Update Type: delete and XML Path: /pkg:package/pkg:part[0] but nothing happens. The XML I want to update:
 <?xml version="1.0" encoding="UTF-8" standalone="yes"?> <!--<?mso-application progid="Word.Document"?>--> <pkg:package xmlns:pkg="http://schemas.microsoft.com/office/2006/xmlPackage">     <pkg:part pkg:name="/_rels/.relspkg:contentType="application/vnd.openxmlformats-package.relationships+xml" pkg:padding="512">          ....
I noticed an error in my Log
 XMLWordTableUpdater_2_XMLUpdater(XQueryFactory2): The following error occurred while executing query number 1: XMLWordTableUpdater_2_XMLUpdater(XQueryFactory2): The following error occurred near line 2, column 8 of the query: XMLWordTableUpdater_2_XMLUpdater(XQueryFactory2): target expression is empty sequence
 If I use /pkg:package/pkg:part[1] for XML Path i don't get an error, but it still doesn't do anything. Does it start to count at 1 here?
Do you know what is causing this problem? What should I use for XML Path?
Best regards, Melanie
